Battery indicator issue 🔋
Bugbear
My asus rog phone 5 shutdown due to low battery. I plugged it in and turned it on normally. I had set charging limit to 90% but when i checked after some time it had already charged to 99%. Now it has been staying at 99% for the last 45mins even though i was using the phone, and even played games for 20mins.
ARP_ASUS
Community Legend II
Please share your software version:
Go to setting => System => About => Software information.
Make sure you are on:
https://zentalk.asus.com/en/discussion/47461/210420-rog-phone-5-18-0840-2103-26#latest
Try charging cycle:
Charge battery to above 90% and discharge while using till 10% repeat for 2-3 cycles
Factory reset
If none of the above work please report back.
Bugbear
On normal use this doesnt happen, it happens only after phone shutsdown due to low battery. It was resolved after first cycle. Now sometimes battery charges to 91% but it goes down normally.
