Battery Drains drastically specially when ROG 5 is in ideal mode
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-15-2021 02:42 PM
Model Name:ROG 5
Firmware Version:Have Attached My System Details
Rooted or not:Not
Frequency of Occurrence: After MOBO change
Battery Drains drastically specially when device is in Ideal Mode..
I use AOD 07:00 AM to 23:00 PM everyday..
I noticed this in specially Holiday, Don't use that much still battery Drains..
Sometimes when I leave my device overnight, battery drops 10-15% is it normal? I don't think so..
Having 6/7 hour's of SOT is not normal in a 6000 MAH battery..
Before faced Wifi/HOTSpot problem now this thing happening! Don't know what are they doing??
I have attached a screenshot, device is in ideal mode along all day, requesting you please tell me is this normal or not??
I don't use mobile data often, I am always use WIFI)
Model Name:ROG 5
Rooted or not:Not
10 REPLIES 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-15-2021 06:56 PM
My setting is dynamic, auto refresh, aod 5am-12am, I restricted battery usage for most apps installed by myself except WhatsApp;
If I left my phone over night (6hour%) with wifi n data on, it will drop 6-8%;
If I left it with wifi n data off, it will drop 2% over night (6hours). For your reference n comparison.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-16-2021 01:58 AM
My setting also dynamic with Auto Refresh Rate all the time, Battery Charge limit is 90%
How the restricted battery usage for any app? What problem arises if I restrict battery usage for any app in my device? Can you Elaborate Please!
You are so lucky? I tried many things but no luck, let's hope this thing works!
Thanks for your reference 🙂
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-16-2021 02:20 AM
Hello Friends!! I have uncheck all the unwanted apps by starting boot up, can this help in my battery life? Any problem with that?? Please help.
Also in settings there is an option named "BATTERY OPTIMISATION" with both option named NOT OPTIMISED/ALL APP? everytime when I press back then enter BATTERY OPTIMISATION always showed "NOT OPTIMISED"???
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-16-2021 08:29 AM
Indr@@@@@123It's ok for me so far after I restricted battery usage for most of the app I installed myself including armoury crate n all apps work normally.My setting also dynamic with Auto Refresh Rate all the time, Battery Charge limit is 90%
Only WhatsApp I set for not optimized under battery bcoz I face an issue of delayed/no notification for Whatsapp messages.
U may try to install an app namely electron from playstore to observe your battery level. The data shown is exactly the data in adb command. Mine real capacity is 5496mAh (shown in photo) but I'm told by another user that not to worries about those figure as long as our phone can last for games 5-6hour, other usage more than 8hours. U may try install n compare.
Btw, My setting is on for "optiflex" n "auto select based on app usage" ; " background app management" is off. These setting seems allowed to drain the battery but I feel not much affected. I only observe a faster drainage when I play mp3 for hours but still acceptable.
Bluetooth, location off all the time for me.
Sorry I'm not well versed in tech stuff n not able to diagnose your problem but only provide u my setting for your reference.
