Air Trigger Problem, Fingerprint, Speaker.
arpastene
Hello group. I have the problem that my ROG5 started with the problem that the air triggers stopped working then the fingerprint reader stopped working correctly, when the middle button sounds the lower speaker. I factory reset it and it continues with the problem. If someone can guide me that unknown because of what is happening.
AndreanPutra
I also experienced the same thing, but for that we can only wait for Asus to answer, is it a bug or does it come from faulty hardware.
