Tick' Tick Sound
ark9127
Sometimes at random Phone makes a ,'Tick - Tick' sound whenever I opened any app and it continues for a short period of time.
ark9127
I had observed that it is making this wierd sound when I play a video in any platform. For e.x. YouTube, video in phone, armory Crate..
ARP_ASUS
Community Legend II
Try the below:
Make sure you are on latest software version which is .78, you can check by
Go to setting => About => Software information
Factory reset your phone once
Share a video if possible capturing the issue.
For quick solution:
Kindly visit the nearest service center:
Due to the lockdown, service centers may not be functional. Kindly call the service center before you visit one.
https://www.asus.com/in/support/service-center/india
ark9127
Yes, I do have the latest software version installed i.e. .78. I usually keep my phone on silent and then only this sound start which is after a some period of time. When I changed the sound setting from silent to sound, then this weird sound automatically goes off. I will surely record the video and share.
Thanks for your quick response. 🙂
