Squeeze the phone for x mod not working problem
Aditya1017
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
4 REPLIES 4
Aditya1017
Model name Rog phone 3
Firmware version 17.0823.2007.58
Not rooted
App name x mode
After update my Rog phone 3 . x mode and live wallpaper can't change after squeeze the phone.
Buster
Aditya1017
Not rooted
App name x mode
Hey use the live wallpapers by asus before applying it change the wallpaper with any other normal one and go to themes use live wallpapers then
This should work 🙂
ARP_ASUS
Community Legend II
Hi Aditya,
Try this:
Activate Air triggers from quick tile
Hold the same from Quick tile and it takes you to Air triggers settings, there you can setup the way you want
You need to change Live wallpaper to see the effects
X-mode can be turned on normal wallpaper as well, its just the effects are only visible on the Live wallpaper which is pre installed on ROG Phone 3.
Aditya1017
Thanks it's working now...
