Rog phone 3 signal problem
sajid46000
I'm having signal problem with my Rog phone 3 suddenly disappear and come back in few seconds its happening more often
10 REPLIES 10
t0mth3cat
hello, i did a firmware update to WW-17.0823.2102.143. solve my problem so far.
sajid46000
Saifuddin
Also check where its says Tencent on back of your device and if you are using global rom ?
It is Tencent and with global ROM as well does it make any difference
sajid46000
AmitGarde
https://zentalk.asus.com/en/discussion/47816/rog-phone-3-signal-problem
Reinsert your sim card and check again.
Still have same problem
GREEKLEADER
Zen Master I
sajid46000
https://zentalk.asus.com/en/discussion/comment/165545#Comment_165545
Of course,it makes a lot of differences
One of them being that band support etc is very limited or unusable for example
Or performance drops,overheating etc
sajid46000
GREEKLEADER
https://zentalk.asus.com/en/discussion/comment/168513#Comment_168513
I'm using that phone form September never had this problem before
