Rog phone 3 signal problem
sajid46000
I'm having signal problem with my Rog phone 3 suddenly disappear and come back in few seconds its happening more often
10 REPLIES 10
AmitGarde
Community Legend II
sajid46000
Reinsert your sim card and check again.
Saifuddin
Zen Master III
Also check where its says Tencent on back of your device and if you are using global rom ?
MrBlackCrush
Rising Star II
I have a strix version and also I randomly have the problem with 4G, both sim 1, sim 2, reinsert etc... so is not tencent problem
I've heard u need to modify the APN, but the phone doesn't let me do it, cancelling the changes I do.
I've only solved by using the Wifi when I'm in an important gaming session...
Anders_ASUS
Hall of Fame III
sajid46000
simo97.codega
I can send you both a PM with log instructions
