ROG Phone 3 Not Charging
543V4
Model Name: ROG PHONE 3
Firmware Version: 31.0210.0210.230
Rooted or not: No
Frequency of Occurrence:
My ROG phone is unable to charge by original charger/cable . However same works fine when used via side port. Thought port might be problem, but it works if i connect with other chargers ( fast charge won't work though). It is and must be software issue, please give me a solution as soon as possible.
9 REPLIES 9
ARP_ASUS
Community Legend II
Hi 543V4 ZT-fdcf9d8b,
I have sent you a message in your inbox, please have a check and let me know.
543V4
543V4
Also bro original charger only working on side port.
Same for me too original charger only working on side port
543V4
ARP_ASUS
Done, not working either
pemaw12
Mine fluctuates, starting to charge as high as 60-70% per hour and soon dropping to negative levels. On both ports. But other chargers work just fine.
ASUS_Bot
Rising Star II
