Rog 3 air triggers issue, please help
BraVø
After the recent update i noticed that the right air trigger is pressing from the back of the phone, this keeps happening any suggestions to fix this? Thank you.
6 REPLIES 6
RAIDEN_
Rising Star II
رختـر
Dont use any case or cover while using Airtriggers and check whether the issue still occurs
BraVø
RAIDEN™
https://zentalk.asus.com/en/discussion/54475/rog-3-air-triggers-issue-please-help
Unfortunately it's still happening, I tried factory reset twice but nothing changed, I wonder if this will be fixed in upcoming updates
ronald1985
Community Legend I
رختـر
https://zentalk.asus.com/en/discussion/comment/192465#Comment_192465
Can you provide your firmware version?
If factory reset doesn't work then I would suggest you go to the service centre.
BraVø
ronald1985
https://zentalk.asus.com/en/discussion/comment/192470#Comment_192470
I'm on the latest update:
18.0410.2109.172
I don't think it's a hardware issue because it happened after the latest update, before that there weren't any problems with the air trigger.
