09-29-2020 12:22 AM
09-30-2020 04:39 AM
robustagundamYep. For quick fix, u can apply this. But for now, no way to activate both simhttps://zentalk.asus.com/en/discussion/comment/120403#Comment_120403
just disable your sim2 in seting to make simcard1 works
09-30-2020 04:41 AM
edwin.wahyudi.07yep waiting for the besthttps://zentalk.asus.com/en/discussion/comment/120406#Comment_120406
09-30-2020 11:34 AM
10-01-2020 12:59 PM
10-03-2020 05:07 AM
edwin.wahyudi.07Same condition and issue,. tell me if issue solved Bro @edwin.wahyudi.07,.exactly same problem.
using network carrier from Indonesia
SIM 1 = Telkomsel
SIM 2 = XL
If i enable sim 1 & sim 2, then my sim 2 prompt "sim 2 not allowed", and my sim 1 also got no network
if i disable sim 2, my sim 1 works fine
already tried to swap sim 1 & sim 2 place. same result
already check the sim card on other device, no problem with the sim card
WTF with this phone man -_-"
