Lens flare issue while capturing bright sources like led Bulb.
altamashdx
Hey Asus family,
Hope all are doing good.
I recently purchased ROG 3 and noticed lens flare while capturing bright objects. Is it normal or is their any defect with the camera? Moreover,lens flare didn't pop up when I tried capturing the same light source with my another phone (oneplus 5t). Why is it so?
ANY ROG 3 USER EXPERIENCING THE SAME?
4 REPLIES 4
AmitGarde
Community Legend II
altamashdx
Hey Asus family,
No need to worry it is just a light's reflection.There is no problem with your phones camera lense
Enjoy your new Gaming beast ROG 3! 😊
altamashdx
Thanks buddy.
But why does the flare not pop up when I click with other phone?
altamashdx
Any ROG 3 owner facing the same issue?
Danishblunt
Hall of Fame I
Depending on lens size and such it will differ, lens flare is very normal. If you hold your OP5 in a certain angle you'll also fine the same result there, no phone is free from this, some are more prone to it than others as well. The IMX 686 is one of the more lens flare resistant lenses, the OP8pro or Oppo Find x2 (using IMX 689) has way more severe lens flare problems.
