03-02-2021 09:38 PM
03-04-2021 12:26 AM
Gustav_ASUSYes but when i connect aero cooler it doesn't work@nardi123.sylasani You should be able to charge using one port and use the other one for your earphones. 🙂
03-04-2021 12:27 AM
CravenHave u tried using aero cooler?Which port goes to which cable? I have the same setup as well with the cetra at the bottom port and the charging cable at the side port (near the vent) and i have no issues with audio nor charging. Actually, i can just use either ports and still have no problems.
I don't use an adapter but when i use the fan and plug the cetra in it with the charging cable on the bottom port, that's the time i get connection problems, in this case, i just swap the cetra and the charging cable and it's back to normal.
03-04-2021 04:41 AM
nardi123.sylasaniThe AeroActive Cooler will take data stream priority. Try connecting the earphones to the fan and charge using the bottom port and see if that works. If not, let me know.https://zentalk.asus.com/en/discussion/comment/155256#Comment_155256
