How can we connect wired headphone and charger without Aeroactive cooler?
abheeshek_agarw
The Aeroactive cooler has ports:
Type C port for charging
3.5mm jack for wired headphones
The fan makes a lot of noise, and disturbs co-ordination while playing with other players. I always have to switch my mike off to play with the cooler
The bulge created by fan obstructs my ring and middle finger required for stability while playing FPS games
Is there a way to connect wired headphones and charging cable without the cooler? Like a separate accessory? or an alternative? (Bluetooth headphones have a 0.5s or 1s lag. Dont know why, if anyone can suggest me debugging options for bluetooth headsets too, that will work)
9 REPLIES 9
ADH
Rising Star II
Hello there ,
You can use c to Aux cable in box .
You can connect one port to charger and other to headphones using C to AUX cable .
About bluetooth headsets i never faced these problems maybe try some other pair of headsets .
Gustav_ASUS
Community Legend III
@abheeshek.agarwal As the user above said, please use the USB-C adapter that came with your phone, if you want to use your 3.5 mm earphones without the cooler fan connected.
abheeshek_agarw
That I understand I can use the adaptor to connect wired headphones.
I also want to utilize the bypass charging functionality of my phone while I have connected wired headphones(Which is possible when I use Aeroactive cooler, it has 2 ports type C and 3.5mm jack)
botboy444
Zen Master I
abheeshek.agarwal
Use the usbC port on the side of the phone 🙂
