bluetooth pair problem
commandoash
Model Name: ROG 3
Firmware Version: WW_17.0823.2102.143
Rooted or not: not
Frequency of Occurrence: always
Bluetooth can never be paired to Citroen C4 Picasso 2014, it always asking me to input correct pin, but without a place to input, how to solve it?
thanks!
Anders_ASUS
Hall of Fame III
commandoash
  1. Model Name: ROG 3
  2. Firmware Version: WW_17.0823.2102.143
  3. Rooted or not: not
  4. Frequency of Occurrence: always
thanks!
There's always risk of two BT units not being compatible but hopefully, all you need to do, is to reset your BT.
You can do this in system settings -> system -> reset options -> reset wifi, mobile & bt
If this doesn't help, then last resort is to backup and run a full factory reset
commandoash
Thanks lot, I've tried all the rest methods and even update the firmware of my car, but didn't work... so the last step is factory reset...but first to make a back up is a big task...
Anders_ASUS
https://zentalk.asus.com/en/discussion/47089/bluetooth-pair-problem
