11-09-2020 08:04 PM
11-09-2020 10:59 PM
SaifuddinI got 1 hour less SOT after 99 update. I got 11. earlier.Please tell us some basic information before asking for help:
- Model Name: rog 3
- Firmware Version: .99 (also did factory reset after .99 update)
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Last charge around 90-93%
I also used whatsapp for a good enough time and many apps but none of then is here
And also only getting 1 hour 10min SOT with 30%charge decrease
Also using dark mode all the timr, light mode uses double the battery
Also did a factory reset after .99 update
Please fix battery usage data information missing issue and increaae SOT
Having less SOT the other 4000MaH mobiles
Battery issue
11-10-2020 12:45 AM
11-11-2020 11:13 AM
