01-03-2021 12:22 PM
01-04-2021 12:21 PM
eqlm2Okay well I'm going to send it off to Asus so I can get it fixed hopefully they just give me a new device. I know opening the insides of these phones and putting them back together can be very annoying.
https://zentalk.asus.com/en/discussion/comment/144513#Comment_144513
It is not true,
He has an issue. Man it is 6000mA battery, even a samsung with 3000ma can give you more SOT than this.
Dont forget mine is charged to 80%
Comparing my battery with other phones which have smaller batteries, it is not ok either. But it is better than his.
01-05-2021 03:00 AM
01-05-2021 06:50 PM
nightmaster552What is your take on the situation then?Looking at people having 0 clue is amusing.
01-06-2021 07:45 AM
NengahWhen playing certain games the screen uses its high speed refreshrate on touch. That drains a lot of battery, hence your SoT seems very bad but its actually normal. Charge your battery up to full charge, don't play anything for an hour and youll see your value is low and normal, play wilf rift again, your screen will zap electricity. It's perfecly normal, most users here have 0 clue so listening to them is like listening to a 7 year old kid talking about aliens.https://zentalk.asus.com/en/discussion/comment/144981#Comment_144981
01-07-2021 10:24 PM
nightmaster552Okay thank you for your input it means a lot.https://zentalk.asus.com/en/discussion/comment/145135#Comment_145135
