Battery drain
jptripathy576
Battery drain is ridiculously high how to fix this
ARP_ASUS
When you say that your SOT(Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. Settings => Battery => Check the screen & share the same
4.Please also mention your phone's software version
