Battery Drain in Asus ROG Phone 5
Model Name:ROG Phone 5
Firmware Version:
Rooted or not: non root
Frequency of Occurrence: Daily
I've noticed that there is a battery drain in my phone.
It's giving very less SOT given the 6000 mah battery. In normal usage I'm getting 8 hrs of SoT but I should get 10+ hrs.
4 REPLIES 4
ImAzygos
Wrong thread. Plz post in Rog 5 thread
Saifuddin
Zen Master III
duttaswaroop00
  1. Model Name:ROG Phone 5
  2. Firmware Version:
  3. Rooted or not: non root
  4. Frequency of Occurrence: Daily
If its rog 5 then i think its pretty good compared to how bad thermals are of rog 5
ARP_ASUS
Check your previous thread.
duttaswaroop00
  1. Model Name: ROG Phone 5
  3. Rooted or not: Non-Root
  5. APP Name & APP Version (If your issue relates to the app): No Specific App
It's giving very less SOT given the 6000 mah battery. In normal usage I'm getting max 8 hrs of SoT but I should get 10+ hrs.
Closing this thread.
Lord_Messi
Zen Master II
duttaswaroop00
ROG 5 have crap battery usage
I hope they fix it at next update
Good Brand worse quality
