BATTERY DRAIN FAST .78 UPDATE ROG PHONE 3
devicentextian
Rising Star II
Model Name:ZS661KS
Firmware Version:.78
Rooted or not:not
Frequency of Occurrence:
128 REPLIES 128
joshua_aquino18
And one more think before i sleep i did turn on airplane mode and if i turn off the data got slow.. how will do it.
Eiji
Anders_ASUS
Please do this
  1. clear you play store app cache
  2. restart your phone
  3. fully charge the battery
  4. if you still experience battery drain, then please let me know and we can log your device
Update. I tried this and it won't work. The battery is still draining fast. I hope Asus will fix this issue as soon as possible.
ammar22371
What do I do, do I update the device or not, please reply back
Eiji
ammar22371
The great about this recent update is the bypass charging. The bad is, black crush is much worst and the battery drain so fast. If you're using the phone regularly outside then you should probably skip it.
ammar22371
I want it to happen to the device, but I am afraid of the battery draining issue. Is it possible for Asus to send another update to address this issue?
