ASUS ROG 3 LOW CALL VOLUME
hllsynotebook
Rising Star II
The sound in calls is very low even at the highest level is very low since the first day I got my latest android 12 installed phone like this android 10 11 12 they are all the same PLEASE UPDATE FOR ASUS CALL AUDIO Admin, you opened the topic in the wrong place, you can delete it
15 REPLIES 15
Danishblunt
Hall of Fame I
1.) Wrong forum
2.) Its not the phone, it's the lack of VoLTE.
And no, they won't add VoLTE for you.
hllsynotebook
Rising Star II
no volte no Google Duo and WhatsApp tada the sound is too low problem in software you don't answer my questions please
keren_ASUS
Hi @hllsynotebook
Thank you for reaching out. Can you make sure your ROG is up to date with the latest firmware? Also, please reboot your phone in safe mode to see if the low volume issue persists. Thank you!
hllsynotebook
Rising Star II
latest software installed and the problem has been since android 10
