09-08-2020 11:34 AM
09-09-2020 05:25 AM
09-09-2020 10:36 AM
09-09-2020 11:13 AM
ARP_ASUSYes SOT is good. I started noticing this issue after .58 update. Before that Screen always used to come on top which makes sense since it will take most battery. It occurs in every charge cycle.Hey,
Noted your feedback seems the SOT is good though.
Can you tell me is it only occurring on .58 software version?
Every charging cycle you see the same?
09-11-2020 05:55 AM
