Memory card problem
My zenphone 3 damage memory cards after afew months.Any one with such issue? Recently change my memory card to "READ ONLY", so I cannot format or delete file from it(with phone and pc).
ServiceH_ASUS
Hi saeid.ektefaie Good day. What's your phone’s firmware version (Settings > About > Software information > Build number) Please also change another SD card for a check. I would suggest you backup SD card files and format it via PC again. If this problem still appears, please check the card is write protected or attacked by virus Besides that, you can also try diskpart or SD card formatter tool to format your card. Sorry for any inconvenience this may cause.
