03-19-202202:07 AM - last edited on 01-16-202401:13 AM by ZenBot
System: ASUS Zepherus G14 - GA401QM Battery or AC: Both Model: GA401QM Frequency of occurrence: Always Reset OS: Done and will not help Screenshot or video: ======================== Detailed description:Just opened the new laptop and while starting what I discovered is the stupid Coil Whine with this laptop. When none of the fans are running I can hear the audible coil whine and when the fans starts Whine Stops and it's normal. I bought this laptop for work and don't want that head banging Coil Whine Noise - So what are my options? I am sensitive to coil whine and this is heartbreaking. Any good help? Cheers,
Hey.. All my BIOS is up-to-date.. yet the problem still lies.. only way the whine goes away is to turn on the fans even they are running in lower RPM.. was looking to a way to use a custom curve with 5% fan speed and not zero
Hi there, When running the unit, there may some coil whine from the component. If the whine is still disturbing you, I suggest you go to service center to do further inspection. Thank you.
