- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-08-2024 11:42 PM - edited 07-08-2024 11:44 PM
I have 2 pcs XT9 on delivery and want to go sure I wont mess the setup.
The initial ISP ONT wifi router will be converted by my ISP into converter mode only and one XT9 will be set up as router, another one as hardwired node.
Now my question is, should I do some specific settings related to IPTV? I have 3 IPTV setup boxes connected on Ethernet, 2 will be connected to XT9 router LAN1 port (switch involved) and the 3rd to Node LAN1. So the stream will go via backhaul line.
Anything needs special attention? Thank you!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-14-2024 03:22 AM - edited 07-14-2024 03:24 AM
Seems that I need to reply on own posts, maybe this will help someone else.
In my specific case the XT9 cannot be used as router, I had to set AP mode as the IPTV provider is NOT sending IPTV signal to other brand routers, the signal is available for distribution in the home network only through routers supplied by the ISP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
