Z790 GAMING WIFI7 and 4090 problems
I have been having trouble with this board running my 4090 is this board recommended for the 4090 or would you be recommending a better board for that card it doesn't seem like this motherboard has enough power for it and I've noticed a bunch of issues running my 4090 with it. What would you recommend the max graphics card before this specific board and would you recommend going with the Maximus hero instead. Can this board safely run 1200 watts power supply
smyasin
Hello,
May I know what specific issues you have experienced with your 4090 and this motherboard?
Your motherboard is designed for 14th-generation processors and optimized for gaming performance, meeting the essential requirements for high-end gaming.
It features PCIe 5.0 slots with SafeSlot technology, providing reliable support for heavy and large GPUs. These slots are directly connected to the CPU, ensuring full bandwidth utilization.
If your 4090 is an ASUS model, I recommend checking your motherboard’s BIOS settings, ensuring it is updated to the latest version, and verifying the latest driver and firmware updates for your GPU.
As for your power supply, if it meets trusted quality standards, there’s no need to worry. High-wattage power supplies will not pose any issue since the motherboard automatically manages and aligns everything with the PSU. Ensure all connections are secure and properly set up for safe operation.
Additionally, ASUS Maximus series motherboards offer exceptional performance and higher durability in demanding gaming scenarios and extreme conditions, making them a great choice for intensive use.
Best regards .
