Does ASUS X670-Prime's V-M.2(E-key) Wifi slot supports WIFI-7 ? (MT7925 or etc...)
Mosh
I read the manual and couldn't find information about M.2 Wifi slot.
Can it cause the bandwidth problem or  something?
Jiaszzz_ASUS
Hello @Mosh
Thank you for reaching out to us.
Could you kindly clarify the exact model you are inquiring about? Is it the PRIME X670-P, or another model within the PRIME X670 series?
If the motherboard does not come with a built-in Wi-Fi module, you can enable Wi-Fi functionality by installing an additional Wi-Fi module.
However, if the motherboard includes a built-in Wi-Fi module, it may be necessary to disable it in the BIOS to avoid potential conflicts with the additional module.
It is ASUS X670-P-CSM (NO Wi-Fi).
Can I use MT7925 for Wi-Fi 7?
Hello @Mosh
Based on information found online, the MT7925 is a Wi-Fi card that uses a PCIe x1 interface.
Referencing the PRIME X670-P-CSM manual's Expansion Slots, this specification is compatible with the four PCIE slots available onboard.
You can select the appropriate hardware configuration based on the motherboard's specifications. For further confirmation on hardware compatibility and support, we recommend contacting its supplier.
Thank you!
