Connect a second monitor z790 proart
Yllen
Hello,
Have two monitors with HDMI and Displayport connectors.
I connect the first monitor to HDMI. Where should I connect monitor number two?
Pc with z790 proart creator Wi-Fi and no separate Graphic card.
1 ACCEPTED SOLUTION
Accepted Solutions
Yllen
I finally understood the Asus manual. I purchased a USB-C to HDMI adapter and plugged into the Thunderbolt port nr1.
Problem solved.
Yllen
Problem solved.
