05-20-2021 06:01 AM
05-24-2021 01:34 AM
Aryan202Sound cool, looking forward to get Megafon RUS VoLTE support as well, because MTS is my business SIM card with limited traffic, while on personal Megafon I have no limits and I use this SIM most of the timehttps://zentalk.asus.com/en/discussion/comment/168037#Comment_168037
Rog 3's latest ota enabled volte and vowifi on an Russian carrier called MTS today by the way
It's stated here in the changelog :
https://zentalk.asus.com/en/discussion/48507/210519-rog-phone-3-zs661ks-ww-17-0823-2104-147
Zenfone 7 should get that support too imo as rog 3 has it now
05-26-2021 09:06 AM
05-27-2021 09:46 AM
AndroidI've enabled VoLTE and VoWIFI on my ROG Phone 3, and I'm on T-Mobile in the US. There is a way to forcibly enable this, but I don't believe I can directly link to it here. I would just advise searching for info on XDA and such.VoLTE is the most requested feature that everyone has been asking for.
The main thing that ASUS seems to mess up the most is full carrier support. From missing network bands to not being compatible with VoLTE and/or 5G with some carriers.
I hope that the current ROG Phone 5 or whatever the next phone is will be fully compatible with T-Mobile.
06-06-2021 11:39 PM
topolovhttps://zentalk.asus.com/en/discussion/comment/168182#Comment_168182
AdminVoLTE and vowifi enabled for MTS and some Tele 2 carrier in zenfone 7's latest ota by the way【Version】
30.41.69.66
【Model Name】
ZenFone 7 Pro (ZS671KS)
ZenFone 7 (ZS670KS)
【Release Date】
2021/06/07
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
- Improved system stability(20210405)
- Updated Android security patch
- Enabled VoLTE/VoWifi on MTS/Tele2 (RU)
- Fixed issue which could cause Gboard settings to periodically change back to default values
- Fixed Status bar display issue
- Fixed reboot issue when using wifi hotspot ocassionally
- Fixed the problem of not seeing thumbnails in computer after upgrading Android11
- Added SMS type QR code support in ASUS Camera app
[210602] ZenFone 7 Pro / 7 _WW_30.41.69.66
06-07-2021 02:51 AM
Aryan202Thanks, I saw, now waiting for Megafon supporthttps://zentalk.asus.com/en/discussion/comment/168183#Comment_168183
https://zentalk.asus.com/en/discussion/49082/210602-zenfone-7-pro-7-ww-30-41-69-66
