on 01-29-2024 05:57 PM
[Wireless Router] How to setup Guest Network Pro (SDN) across AiMesh and managed switch?
Conditions:
1. Check your device, this FAQ is for ExpertWiFi series or selected models with Guest network pro feature.
ASUS ExpertWiFi|Business Network Solutions|ASUS Global
[Wireless Router] What is guest network pro? How to use it?
2. Make sure your switch is a managed switch(L2 switch) supports VLAN.
3. In this example, we will create two SDNs, VLAN 52 as a VPN WiFi, VLAN 53 as a Guest portal.
4. In this example, we target to setup port 1 as VLAN 52, port 2 as VLAN 53 on all AiMesh Router/Node and switch. Switch LAN port 3 as a management port to access AiMesh management GUI.
5. AiMesh node connect to AiMesh router via Ethernet backhaul.
Connection settings:
1. AiMesh router LAN 3 connect to switch port 5.
2. Switch port 4 connect to AiMesh node WAN port.
AiMesh router/Node VLAN settings:
1. Port 1: Select target SDN(VLAN 52), access mode.
2. Port 2: Select target SDN(VLAN 53), access mode.
3. Port 3: Use “All(Default)” mode.
Switch settings:
port 1: untag 52
port 2: untag 53
port 3: untag 1
port 4, 5: untag 1, tag 52, 53
AiMesh node settings:
1. Select the node
2. Select management
3. Set backhaul connection priority to 1G WAN(or 2.5G WAN) first.
