01-04-2020
11:40 PM
- last edited on
01-16-2024
01:27 AM
by
ZenBot
01-06-2020 12:06 AM
04-02-2020 06:41 PM
vince.disametoI too have the same problem. I did a trick from XDA forum. Not sure it will work for you.Thanks man.tried it but still not getting signal
04-09-2020 11:36 AM
mastershuIt worked...thanks man I was worried since morning as during this lockdown having a network is a must...I was sceptical but as per the research there's some issue with the antenna cable...and you made sense though. Thank you once again 🤘🏻https://zentalk.asus.com/en/discussion/comment/38509#Comment_38509
@vince.disameto its tricky an takes patience but this is what i was told an it worked.... take simcard tray out..... SQUEEZE THE HELL out of the area the tray goes into top of screen an back of phone an while doing it put tray back in an keep squeezing while turning on phone let it go when home screen appears... i had to do it 3x but it worked.... apparently antenna is next to sim tray an it comes loose if taking out sim tray an pushing pin in wrong
