Enabling camera2API on Zenfone Max pro M1
Kenvik
I had camera2api enabled on my Zenfone Max Pro M1 when it was running Android Oreo. But after updating to Pie, it got disabled and now I'm not able to enable it again. Enyone know how to enable it? I need it for using Google Camera.
Yachendra
Rising Star II
Yes, camera2api will be disabled if you upgrade version from Oreo to Pie(Even it will be disable every time you perform factory reset the device).
You can follow the same procedure that how you enabled camera2api in Oreo.
mahdigold10
Yes true I accep
