Battery calibration issue
- Model Name: ASUS 6Z
- Firmware Version: LATEST (A11)
- Rooted or not: no
- Frequency of Occurrence: Every time
- APP Name & APP Version (If your issue relates to the app): Battery
What the hell is this bug. This is so random. It is like battery calibration has not been done properly. I have to restart my phone everytime this happens. Also the battery life is pathetic. I have reset my phone twice and this still appears.
Anybody else having this issue?
Comments
Software version : "Latest on Android 11" ...
Please note that not everyone is on what you call latest version (since 2 versions exist on A11). Which version do you use ?
Is it happening even after a restart and in safe mode too ?
I will try in safemode as well as this bug is random for me.
Also i discovered that the flip camera toolbar is not working with 3rd party apps like whatsapp camera, flashlight and google duo(i have tried it in safe mode. It is not working).
This used to work very well in a10.
Try deleting all the data in this application, and test the battery again.
Is the flip camera toolbox working with the swipe gesture ? The second on your screenshot.
Its not working for me...
Even after a restart ? And in safe mode ?
It does works fine, the thing is we need to swipe it up bit more than usual
I am still getting icon to rotate camera...not a scrollable one
toggle (turn off and turn on) the option to enable 3rd party app support once from the adv settings and reboot
I did it but did not help i have reset my phone 3 times but no luck. I downgraded to a10. Hence the late reply
If I was going to go down to A10, I should have tried a hard reset on A11 first.
The swipe gesture is not working either.
Downgraded to a10. Will wait for stable a11 upgrade
Didnt i mention that. I did it 3 times. I will never do a do soft reset. I will backup first
Thanks for reporting. The same same has been forwarded for additional check.
