Battery drain
- Model Name: Asus 6z
- Firmware Version: Latest
- Rooted or not: Not
- Frequency of Occurrence: NA
- APP Name & APP Version (If your issue relates to the app): NA
Noticed this today. I'm having battery drain issue. I used to get higher SOT but now it's like the first 10-20% drain very quickly. This is ongoing for a couple of weeks now.
Comments
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Please follow the below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
I will share once my battery is at 10%. I always do keep an eye on background apps. As of now SOT is 1hr 20 mins from using Chrome and youtube battery is at 80% this used to be a lot better. Before I would've got the same SOT with a 11% drop not 20%. Also the problem is with first 20% battery drops quickly rest drains faster than before but not as fast as first 20%
Edit : Its almost a year since I'm using this device, still this is too much for battery degradation
This looks ok, But the problem is really with the first 20%, i used to get better SOT and battery results.
Your battery stats are okay.
Your phone is efficient in the 90-20 % range ...
Avoid to let it drain at a low battery level without charging !
I see. Thanks mate. I'll follow your advice!
