Air trigger problem
When I'm using air trigger, i found out that even when i press the screen or back side near the air trigger, it gets triggered. DowsDoes anyone face the same problem ( sensitivity is set to around 1 to 3. Please help me because if I'm only having this problem, i can replace it. Thank you
6
Comments
I had faced the same while playing Call Of Duty and between matches where you need not use the air triggers. Kindly update to the latest firmware version that is 16.0631.1908.21 as this new update has fixed the issue. Cheers!
But i didn't get that update here in india
i had other problem that the left triger pressed many times with one press
its fixed by turn off turn on the trigers
I found the root cause of the problem. It's because of the phone bending
i had issues with it befor and after update to 1908
first it was Disappears as soon as i touch the red or blue Circle , now i cant move it to locate it where i want
i hope its fixed as soon as possible
i have updated my phone to this version and also getting issues
Same issue happened with me too but try i tried resetting the tap force level by unchecking the sensitivity booster button(you will get this sensitivity booster button while setting air trigger tap force level at armoury crate).... Now it's working perfectly with me. Try it out guys!
I'm having the same problem for my right trigger (red) I am already using the latest firmware. Tried resetting the force, turning on or off sensitivity booster, restarting the phone. Really hope this is not a hardware issue. I've never dropped my phone.
Temporary workaround: set the trigger level to 9. I realized no matter how hard I push the back of the screen I can only reach force 8.
Try removing the case and press the air trigger. It actually worked for me
The air trigger is working for me, but having the back of the phone also triggering the air triggers is really annoying. Did you managed to get your phone repaired?
No. I don't think it as hardware issue because it partially disappeared with the latest update
Hopefully they push an update soon. I've contacted support and was told to factory reset the phone. It didn't work.
Other than that the phone is awesome so far.
Same issue. Please let me know guys if this is really a hardware issue. Already gave my phone to the service centre but they couldn't fix it either.
Attaching a video for reference.
Let me know if you guys have the same issue.
Hi All,
For people facing an issue with trigger working even when you touch the back of the phone.
I've found out a lame but working solution for now. I recently ordered and applied a skin for my phone.
Turns out, the trigger does not fire now when i touch the back of my phone (now with the skin). So look for some material and place it at the back of your phone (a piece of thick paper) and try if the trigger works then. If not, Voila! ? Just buy a skin or a small paper cutout.
I know this is not a permanent solution, but a temporary fix until the team
comes up with a solution.
Please try and let me know if this works for you.
Initially i had this problem in left air trigger same as urs.it was shifted to right side with the new update. But now it's gone. Like reduced.but i have other issues
If you are able to trigger the Air Trigger when touching the back of the phone, this is most likely a hardware issue and I recommend contacting an ASUS service center.
The separate unresponsive Air Trigger issue should have been resolved with the latest firmware update.
But it just shifted from left trigger to right after the update. My left trigger works perfectly now. So i think it's not hardware issue. And many people are having this issue
So before your left trigger was faulty, and after the latest update you are seeing the same behavior but on the opposite Air Trigger?
I guess that is what he is trying to say over his last 2 posts
In the first post he said it shifted, and then that it was gone, and then that it was reduced. I need to give accurate feedback to the software team to know whether the fix is working or not.
