不能顯示該小工具。
不能顯示該小工具。
取消
顯示結果
搜尋替代
您的意思是:
Fan speed issue
KEVIN_NAH
System: rog zephyrus m15
Battery or AC: Battery
Model: ROG Zephyrus M15 GU502LW
Frequency of occurrence: always
Reset OS:
Screenshot or video:
Detailed description:So it happened a while ago. One time i start to release that there was a fps drop while playing games due to overheating. I found out that the speed of the laptop drops for no reason during games thuz causing it to overheat. When i switch the mode in Armoury crate to turbo mode, the fan speed rises to and stay consistent at 8000 rpm, but after a minute or so while gaming, the fan speed just gets lower for no reason to 6700 rpm.
9則回覆 9
Blake_ASUS
Community Legend II
Hello Kevin,
Which BIOS version and Armoury Crate version are you using now?
And can I have the screenshot or video record of Armoury Crate for the issue?
I would like to see the temperature of both CPU and GPU, and the fan RPM.
KEVIN_NAH
Hi, so the BIOS version is : GU502LW.309. And the Armoury craete version is 4.1.6.0. I will have a video record of the issue later i think.
KEVIN_NAH
Sorry for the language, so the first image is when i switch to turbo mode, and it has a fan speed rpm of 8000. But after a while in the second image as you can see, the rpm dropped to around 6000 rpm, which kinda causes overheating problems and performance issues
KEVIN_NAH
Hello Blake,
So is there a cause to this problem?
