em 05-08-2020 05:01 AM
em 05-10-2020 08:34 AM
treviasxkAnd also widevine L1 is not supportedPlease tell us some basic information before asking for help:
- Model Name: Zenfone Max Pro M1(ZB602KL)
- Firmware Version: QKQ1.WW_Phone-17.2017.2004.424-20200414
- Rooted or not: NO
- Frequency of Occurrence: Ever
- APP Name & APP Version (If your issue relates to the app):
Hello, I found 4 bugs.
1-I can't remove these hint cards in the settings
2-When recording video with the front camera, everything is dark.
3-I can't put HD in PUBG Mobile settings
4-The option to turn notifications into bubbles (Balões) is not working in the developer settings.
I found 4 bugs on Android 10 of Zenfone Max Pro M1 (ZB602KL)
em 05-10-2020 08:35 AM
em 05-16-2020 10:43 AM
amitgarde3Hello, I did the factory data reset and I was using my smartphone for a week to see if the bugs disappeared, but it didn't disappear.After every new OS firmware update factory data reset is recommended this will solve most of the problems and u can experince smoother user interface
Everybody updated to A10 i suggest u to reset your device and get it more optimised with new OS n m sure u ll be happy with A10 also battery backup takes a week to read ur daily usage so commenting earlier on backups is not acceptable
Use ur device for a week atleast after factory data reset and then comment on all ur problems
Thankyou😊
em 05-16-2020 01:10 PM
treviasxkOs cartões de dicas são o padrão do Android 10 design n para outros designs, aguarde a próxima versão estável do firmwarehttps://zentalk.asus.com/pt/discussion/comment/78593#Comment_78593
These hint cards are back, and they don't come out, none of the bugs I mentioned have been fixed.
