Não foi possível apresentar este widget.
cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
I found 4 bugs on Android 10 of Zenfone Max Pro M1 (ZB602KL)
treviasxk
Model Name: Zenfone Max Pro M1(ZB602KL)
Firmware Version: QKQ1.WW_Phone-17.2017.2004.424-20200414
Rooted or not: NO
Frequency of Occurrence: Ever
Hello, I found 4 bugs.
1-I can't remove these hint cards in the settings
2-When recording video with the front camera, everything is dark.
3-I can't put HD in PUBG Mobile settings
4-The option to turn notifications into bubbles (Balões) is not working in the developer settings.
33 RESPOSTAS 33
manojreddy_buda
Rising Star I
treviasxk
  1. Model Name: Zenfone Max Pro M1(ZB602KL)
  2. Firmware Version: QKQ1.WW_Phone-17.2017.2004.424-20200414
  3. Rooted or not: NO
  4. Frequency of Occurrence: Ever
Pubg HD graphics depend upon Processor, play with Smooth and High. That's good for the device health.
treviasxk
manojreddy.budati
https://zentalk.asus.com/en/discussion/27923/i-found-4-bugs-on-android-10-of-zenfone-max-pro-m1-zb60...
The HD option works on Android 9, but on 10 it doesn't work, nor does the high frame rate
Thuban
Audio output of both via headphone jack and speaker is bad.....idk about bluetooth
Screen freeze occurs sometimes
Navigation bar sometimes extends to apps.....doesn,t go full screen
Slow response across ui.... occasionally
No hd in pubg
Plzz..asus fix these problem..in stable version
ankitsh0707
👎Screen brightness isn't that much effective.
They are releasing as OTA update
With so many bugs 🤔🤔
