Não foi possível apresentar este widget.
cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
I found 4 bugs on Android 10 of Zenfone Max Pro M1 (ZB602KL)
treviasxk
Model Name: Zenfone Max Pro M1(ZB602KL)
Firmware Version: QKQ1.WW_Phone-17.2017.2004.424-20200414
Rooted or not: NO
Frequency of Occurrence: Ever
Hello, I found 4 bugs.
1-I can't remove these hint cards in the settings
2-When recording video with the front camera, everything is dark.
3-I can't put HD in PUBG Mobile settings
4-The option to turn notifications into bubbles (Balões) is not working in the developer settings.
33 RESPOSTAS 33
AmitGarde
Community Legend II
After every new OS firmware update factory data reset is recommended this will solve most of the problems and u can experince smoother user interface
Everybody updated to A10 i suggest u to reset your device and get it more optimised with new OS n m sure u ll be happy with A10 also battery backup takes a week to read ur daily usage so commenting earlier on backups is not acceptable
Use ur device for a week atleast after factory data reset and then comment on all ur problems
Thankyou😊
ramu213631
Hinders fullscreen mode in chrome while playing videos and also PES MOBILE2020 cant be played fullscreen because of the navigation bar layout which is very thick. These were the bugs which were noticed immediately.
I use Zenfone Maxpro M1 4gb varient.
Rooted or not: NO
4. PES MOBILE 2020,LATEST VERSION.
(After Android 10 ,Stable version update)
Malav
The customisation card bug is there in some other phones too...I have a Mi A2 android One device and that bug is there for me too...you can clear data of settings suggestions and force stop it to get rid of it for a few days!
Netflix is not working after android 10 update. It says that this appis not compatible with your device
rahulkewlani199
Rising Star I
sandeeprockzzz14
because android 10 is in beta stage and that's y it shows device is not certified in playstore
and u can't install Netflix in non-certified phones, so u need to wait till stable update come
