05-14-2024 07:28 AM
Of course, you can select them in the application's notification settings. However, I have a problem with one application, where after installing it, there is a "none" sound for notifications. When I want to assign a sound, a list appears, but not notification sounds, as is the case with any other application, but sounds for calls, which is some kind of error... So the question is how to bypass this and be able to select sound appropriate for the notification.
And if you don't know, please let me know in which system directory the sounds are saved. I've searched everything (the appropriate ROOT browsing app), but they're nowhere to be found, much less in the standard "System/media/audio" path.
Solved! Go to Solution.
05-15-2024 03:35 AM
05-15-2024 03:35 AM
05-15-2024 04:07 AM
Sorry for accepting as solution - wrong.
App is https://play.google.com/store/apps/details?id=com.tippingcanoe.pepperpl , same as https://play.google.com/store/apps/details?id=com.tippingcanoe.hukd
BTW - how can I change my stupid profile name...? I can't find any option in my profile to do it...
3 weeks ago
I’m having an issue with one specific application where the notification sound is set to "none" by default after installation. When I try to assign a sound, the list that appears contains sounds for calls instead of notification sounds. This seems to be some kind of error.
What I’ve Tried:
Questions:
Any help or guidance on this would be greatly appreciated. Thanks!
3 weeks ago
1. I don't hink there is a way to "bypass" this issue. In my case, I just added an other sound.
2. /system/product/media/audio/
