Wifi connectivity issues
lysbborges
Last edited by lysbborges on 2019/3/3 21:26 Hi I have an Android 8.1.0 Firmware ww_15.02.1810.380_20181130 Model Asus_X018D That is not connecting to the regular home wifi network, where it used to connect automatically with no problem. I believe that after the latest update I started having this issue . I add the password of the network but it does not connect. Can anybody please help? I've tried resetting the phone and the network and I had no success. However it only had this issue with the house network, other places my wifi connects
ServiceH_ASUS
Hi lysbborges Do you mean the phone can not automatically connect but can reconnect by manual connect? Have you tried it under "safe mode"? In safe mode, only the factory pre-installed applications will be loaded. For instructions, please refer to the link below: http://www.asus.com/zentalk/forum.php?mod=viewthread&tid=3105&highlight=safe%2Bmode Thank you:)
