The article you are trying to access is permanently deleted.
04-09-2020 12:07 PM
Solved! Go to Solution.
04-15-2020 12:24 AM
04-10-2020 06:01 AM
04-10-2020 08:18 AM
YeLRaWI want to move the applications, not the application data. This method is normal on Android, but I think that Android 9 does not allow or may be ASUS that does not allowPlease tell us some basic information before asking for help:
- Model Name: Zenfone MAX SHOT ZB634KL
- Firmware Version: WW_Phone-16.14.2002.291_20200121
- Rooted or not: not
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
I would like to know why the zenfone max shot does not allow the transfer of applications to the Android 9 micro SD card
observation I already activated the option to force move applications under development
it still didn't work
I believe it is something from Android 9 or ASUS itself that does not allow it.
transferring applications to MicroSD card Android 9
04-10-2020 08:35 AM
04-10-2020 09:33 AM
hardik.seccI also think that Android 9 does not allow to move applications to the microsd card unfortunately thank you.Move to micro SD card application not allow the transfer the Android 9
