Does not charge after installing OTA update
diegohef
ZF Model: ZC554KL
RAM: 3G
Firmware/APP Version: 3.18.71-perf-g9cb3900
Frequency of Occurrence: When i connect it to the charger
Rooted: No
APP Name:
When I connect the charger it vibrates and the battery logo switches from green to white as if the charger had been disconnected; then it vibrates again as if the charger had been connected and the logo turns green but only for a second as it turns white again. This erratic behavior is worrisome and I'm displeased how the latest update rendered my device useless. It's just like apple throttling their devices.
Y_ASUS
Zen Master I
Hi diegohef, Since which firmware update did this start to happen? * Find the firmware version in Settings > System > About phone > Software information We would suggest you switch to different cables and check again. Thank you.
