ZenFone Max Pro M1 Android 10 beta Emergency calls problem in Turkey.
cengizhankirac
Zenfone max pro m1 emergency call problem was corrected in Turkey. There was a problem on Android 10 too, is this problem fixed on Android 10? Android 10 must be checked before the final version is released.
25 REPLIES 25
cengizhankirac
sokolinskiy88
https://zentalk.asus.com/en/discussion/comment/132458#Comment_132458
This is their standard response, but then nothing happens or changes. They don't care about us at all and what happens to our devices after their crooked updates.
You need to see the psychologist immediately. I wish patience to Asus employees.
cengizhankirac
Christine_ASUS
https://zentalk.asus.com/en/discussion/comment/132231#Comment_132231
Hi cengizhankirac
Thank you for your reply. I have forwarded the information to the relevant department. We will keep you updated and your consideration will be very much appreciated.
No emergency calls are made in the Android 432 beta version. Please apply the gms update made in android 9 to android 10.
Christine_ASUS
Community Legend II
Hi friends
Please note that the latest version of ZenFone Max Pro M1 Android 10 beta WW-17.2018.2012.438 does not fix the situation. For Turkish users, kindly remain in Android 9. I will check with the relevant team for the case and keep you updated. Sorry for any inconvenience it may be caused.
cengizhankirac
Christine_ASUS
Hi friends
Hello Christine_ASUS,
The fix made in Android 9 needs to be integrated into Android 10. This is a serious problem and should be fixed as soon as possible. Please let me know when this error could be fixed in your technical team.
Christine_ASUS
Community Legend II
Dear Customer,
If you encounter ZenFone Max Pro M1 (ZB602KL) Android 10 AOSP developer version will call to 112 while dialing 155/156/158/110/177 in Turkey, for Turkish users, please visit ASUS support site to modify your version to Android 9.
https://www.asus.com/tr/Phone/ZenFone-Max-Pro-ZB602KL/HelpDesk_BIOS/
We apologize for any inconvenience caused and your consideration will be very much appreciated.
Thank you for your continued support and patronage.
