widevine l3 on asus max pro m1 A10 beta 4
gangadhararao
Please anyone help i cannot view hd videos on my phone.
I tried flashing oreo(340), pie(360) and 10 beta 2 stock roms but the issue is not resolved.
16 REPLIES 16
gangadhararao
Christine_ASUS
Hi dibyarupprk2011
Thank you for your reply. I just downgraded my device yesterday from WW-17.2017.2006.429 to WW-16.2017.1912.060 to WW-16.2017.2009.087, yet my device is still in L1.
1. Have you ever unlocked or rooted your device before?
2. Can you elaborate more about your downgrade process? From which firmware version to which firmware version?
Have you flashed beta 1 , i think the problem is with beta 1 when i installed beta 1 my wideline went to l3 , i waited for beta 2/stable update to resolve this issue but didnt resolve.
gangadhararao
Anandu
https://zentalk.asus.com/en/discussion/36413/widevine-l3-on-asus-max-pro-m1-a10-beta-4
DRM Level on mine is L1. V432 . MaxProM1
Are you talking about Youtube? Because That's an issue from YouTube's side for mobile app due to rise in data traffic during Covid!
Even max on mine is 480p.
https://play.google.com/store/apps/details?id=com.androidfung.drminfo
What does this app show your DRM level?
Check Widevine CDM section for Security Level.
I have checked through this app only its showing l3
gangadhararao
Christine_ASUS
Hi gangadhararao
Thank you for your asking. Both of my MPM1 in Android 9 and Android 10 are in Widevine Security Level L1.
2. Do you mean that your device is in Widevine L3?
3. Does the issue appear right after any apps' download or update?
I have unlocked bootloader on android 9 version but after that i have flashed fastboot rom ver 058 and checked widevine is l1 but when i flashed beta 1 this problem occured.
But in beta 1 i never unlocked bootloader and i rolled back using above mentioned fastboot rom.
Christine_ASUS
Community Legend II
Hi gangadhararao
Sure, I have another device upgrade from A10 V407>V424>V429>V432, and the device is still in L1.
2. What is your current firmware version? WW-17.2017.2008.432?
gangadhararao
Christine_ASUS
Hi gangadhararao
About unlocking i said in before comment.
Actually what i did was i flashed beta1 rolled back to 058 via fastboot. After beta 2 update, i flashed and rolled back to 058 via fastboot.
Currently i am on pie(087) build
