When will Asus Max pro M2 get Android 10 Stable version, after BETA 2 ???
shreerangmore
Asus Max Pro M2 : Bugs After BETA 2 Update....
Speakers Sound output is very low
Battery is AVERAGE must be much BETTER (5000mAh Battery)
Wifi Connectivity is not proper
Network Connectivity is laggy
System processes are bit slow, take 2 to 3 seconds after closing any apps, process is displayed in notification bar, this is annoying...
Asus team India, must fix these bugs as soon as possible, customers and asus mobile users are tired of listening to delayed dates of updates of Android 10...
7 REPLIES 7
Y_ASUS
Zen Master I
Hi shreerangmore,
This issue is expected to be improved through a future firmware update. We will notify you once it is released.
Could you tell us more about the battery performance? How does it affect your use?
We suggest that you check with different WiFi routers & locations. Please also try resetting your network settings and try again. (Settings > System > Advanced > Reset options > Reset Wi-Fi, mobile & Bluetooth). Also, please note that WIFI speed will be affected by the environment and the corresponding network settings. The actual transmission speed will decrease according to the interference of the signal in the environment. You may also troubleshoot the problem by checking this article: https://www.asus.com/support/FAQ/1006657/
We suggest that you check with different SIM cards by different carriers. Please also try resetting your network settings and try again. (Settings > System > Advanced > Reset options > Reset Wi-Fi, mobile & Bluetooth). You may also troubleshoot the problem by checking this article: https://www.asus.com/support/FAQ/1012408/
System processes are bit slow, take 2 to 3 seconds after closing any apps, process is displayed in notification bar--> Could you tell us the apps that have this problem? What are the apps that were running in the background when this problem appears? Please also show us a short video if possible.
Thank you and have a nice day 🙂
shreerangmore
Android ten Beta 2 is very handy and performer, bt carries some Bugs, hope asus team india would fix it very soon.....
shreerangmore
Battery performance MORE THAN latest update of andriod pie may security patch... bt the backup of battery must be a bit more it lasts for 8 hours of normal use in android 10 beta 2. it should be atleast 10 hours, which should possibly last till end of the day....
I have strong wifi bt several times it losses connectivity, for normal wifi range for eg; between 3 metres range.
network reception should be strong, might be any of the services providers, the device must be capable of receiving better signals...
Sound output Must be as better as andriod pie 9.
system laggy processes, displayed in notification bar 2 to 3 seconds which is annoying , it happens for almost every app since updates from december patch of android 9........ also it is there now in andriod 10. please fix it.... ber IMAGE attached for reference -------->
shreerangmore
This app is crashing all the time... Which i use very frequently... Plz fix in next update...
