04-15-2020 06:00 AM
04-15-2020 06:43 AM
venkatetWhat is your current Firmware version??Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
While shooting video it keeps focusing and sometimes very blur.
Video camera for max pro m2
04-15-2020 07:46 AM
SanjuCurrently using 73https://zentalk.asus.com/en/discussion/25973/video-camera-for-max-pro-m2
04-15-2020 08:42 AM
venkatetI expected you might be on Beta 10, and if that would be the case then I would tell you that EIS doesn't work in Beta AOSP .409 version.73
https://zentalk.asus.com/en/discussion/comment/71823#Comment_71823
Currently using 73
04-15-2020 08:56 AM
SanjuHow to enable camera to apihttps://zentalk.asus.com/en/discussion/comment/71838#Comment_71838
But as you replied that you are on .073 then can you tell whether the object you were recording, was that a very fast moving object? Asus Max Pro M2 stock camera performance is very very poor. You may try to install Gcam by enabling Camera2API.
