Update Issue
Aontu
I am a Zenphone Max Pro M1 user.
Model: X00TD. Android version: 9.
Facing an system update problem for last 6-7 months. I was notified an update and gone for it to get. When I clicked the menu "System Update", it showed that an update of 61 MB is downloading. But unfortunately it has no result. Then on the notification bar a notification is showing " Unstable Network" though I have tried both mobile data and WiFi. It is so irritating. Please provide me a solution if any and let me know when I will get the next update.
15 REPLIES 15
Satnam
Rising Star II
bro device ko reset karo and then check karo problem sloved ho jayegi
Satnam
Rising Star II
nhi toh fota app ka data clear kar ke v check kar sakte ho ...app
adikole00
Singh
Asus madarchod company hai aisa hote hi rehta hai
usakiyem
Rising Star I
Manually update kar lo beta 3 me its work better then android 9
