Touch screen not works when I turn on the mobile
siro70
ZF Model: ZB602KL
RAM: 4G
Firmware/APP Version: opm1.ww_phone-15.2016.1811.338-20181206
Frequency of Occurrence: Turning on mobile
Rooted: No
APP Name:
Hello, I have same problem when I turn on the mobile. Touch screen not works. I have to close by pressing the start button to force restart. But sometime i have to repeat it several times till touch screen come back to wotks properly.
Y_ASUS
Zen Master I
Last edited by Jei_ASUS on 2019/1/18 13:03 Hi siro70, Does this usually happen after any specific action? During charging/ after booting the phone on? Or just turning the screen on? Usually after your phone sleeps for how long does this happen? Is your ZenMotion turned on? Could you check whether this happens during ZenMotion on/ off? How often does this happen? Thank you.
