05-22-2020 10:00 AM
05-25-2020 08:53 PM
05-25-2020 09:01 PM
Y_ASUSHi mrinmoysan14,
Please provide your firmware version: Settings > About phone > Build number.
We would like to understand whether you're using the ASUS original charger. We suggest that you try with new cables and check again.
Please also note that "fast charging/charging rapidly" appears after a few minutes when you plug in your charger. Please make sure to check your lock screen after a few minutes.
Furthermore, there are some scenarios that may affect the fast charging status:
A. If the system is under high resource usage (high temp) or the battery level is over 85%, the device will trigger a protection mechanism, which lowers the charging current.
B. Check if there is some object or stain in the charging port. We recommend to use a soft brush to clean the charging port.
C. We recommend to test charging in safe mode. How to enter safe mode: https://www.asus.com/IN/support/FAQ/1005163
If in safe mode, the problem is not observed, the system performance may be affected by 3rd apps. We recommend to factory reset the system.
If the charging status is still unstable in safe mode, we recommend to go to repair center for further checking.
If the problem still appears, please tell us at which battery levels does fast charging not work.
Thank you🙂
06-09-2020 08:27 PM
06-10-2020 04:10 AM
Y_ASUSUse orginal Asus charger with proper cableHi mrinmoysan14,
Are you using the ASUS original charger? Have you tried with different chargers and cables?
Does fast charging not appear all the time or sometimes?
