Sd card error
diniezaidi
ZF Model: ZB602KL
RAM: 3G
Firmware/APP Version: 1902.340-20190216
Frequency of Occurrence: Frequent
Rooted: No
APP Name:
Zenfon max pro m1 have a bug. But when you insert new sdcard, format option will appear. If you use that then your sdcard will be dead. 2 months ago i was confused why my sdcard(adata) suddenly corrupted then today i insert a sd card from my other phone and its corrupted too. Tried many method to restore and it failed. Dont use the format option from zenfon max pro m1
Y_ASUS
Zen Master I
Hi diniezaidi, Does it happen in firmware version WW-15.2016.1902.340? Or previous versions as well? Could you tell me your SD card brand and type? Do you have a screenshot of the error message? Please try taking out the SD card and use PC to back up data in SD card. Sorry for the inconvenience caused.
